Spring pin mounts
Do all the XT, LT and NT models have the same mounting ear at the front?
And then the front spring's rear mount...
The top of the shackle is through a hole in the chassis.
Are they all that way?
And what is inside that chassis hole?
If they're not all through the chassis, then are the shackles different lengths?
Or do they all then have a different ride height?
I have similar questions on the rear leaf's mounts, but my focus is on the front at the moment.
I did notice that the driver's side bump stop mount has a bit of a bend to it compared to the passenger's side... so that bump stop seems to have been exercised more.
- Frank
LT front spring front mount has a shorter ear than XT, ie. front of spring is closer to chassis.
LT front spring rear mount is under the chassis, not through it like XT
All this in effect rotates the front diff so that the spring wedges used in the XT are not used on the LT
this also means that the front spring clamp of the LT is different to the XT
inside the chassis hole is an 'orkot' bushing
Frank wrote: XT front spring mounts are different to LT, I have no idea about NT.
Thanks Frank.
Is the chassis captivated bushing for the upper shackle a proper Orkot by Trelleborg like the sintered Kevlar, plastic and molybdenum- like they use on ship rudders?
Or
The metal bearing that looks like a goofball with dimples inside.. which seems to be called an Orkot, but does not seem to be searchable in any way to find sizes...?
I am not sure what the chassis hole diameter is, that is the OD of the "Orkot".
- Frank
^ yes,Holmz wrote: Or
Will have to see if I have any of the old ones I pulled out lying around, from memory they were the same diameter as the bushes in the spring eyes, perhaps someone else can comment on this?Holmz wrote: I am not sure what the chassis hole diameter is, that is the OD of the "Orkot".
Probabaly a reciprocating saw would have helped.
David (still in hospital)
dandjcr wrote: ...
If you have the same aliment as my workmate, then you got not too bad of a situation.
High %'age end up with a happy face.
Anyhow... missing your sage advice.
