How high and long is a Oka
01 Nov 2012 15:16 - 01 Nov 2012 15:17 #1
dandjcr created the topic: How high and long is a Oka
Forum Home > On the Road > How high and long is a Oka
okalover
After much intensive negotiations with the minister of war and finance it seems I now have non divorce approval to purchase a Oka.
however before I do, I need to know if my shed will fit one. so can one measure the hight of one with a roof rach and with out a roof rack, and its length from end to end. many thanks in advance.
Steve
June 17, 2012 at 12:17 PM Flag Quote & Reply
Steve
this is the info you need. An XT Oka bus is shorter than that shown in the table. someone elso here will know by how much. Also be aware that a bull bar will make it longer.
June 17, 2012 at 1:36 PM Flag Quote & Reply
Greg #210 and Dean #366
I think that the XT 300mm shorter but good things come in small pakages
June 17, 2012 at 1:41 PM Flag Quote & Reply
Hank Onthewater
Hi Steve, height I am sure you realise is related to load and tyres fitted, and I suppose, to the fact that the springs may be sagging on an older unit.
My bus/top-pop body is 256 cm, high, while the roofrack over the front cabin adds another 9 cm. My rims and tyres are 19.5, fitted with 265 Toyos. If I were to fit wider tyres, then these tyres we would be taller, raising the height by a few cm. Hank
June 17, 2012 at 2:03 PM Flag Quote & Reply
okalover
Thanks all, you have been a big help, and I look forward to joining the OKA community soon.
Steve
June 17, 2012 at 4:28 PM Flag Quote & Reply
There is 250mm Difference between the early XT Bus body and the later XT and LT bus bodies. OKA extended the Duel Cab and Bus body length after XT OKA 137 along with many other small upgrades. Also many bodies have been swapped over the years so it is possible to have a short body LT Duel cab or Van / Bus originally from a XT
OKA-131 Home Page
OKA Camper Trailer
June 18, 2012 at 7:33 AM Flag Quote & Reply
Steve, following on from the above posts you may not be aware that the actual drivers cab is the only bit that is part of the original vehicle. The other body configs just bolt onto the chassis behind the cab with a sealing strip between the two.
There are differences between the XT and LT cabs other than the obvious like the "bonnet" and the wider instrument binnacle on the LT.
The actual engine bay is wider on an XT which lends itself to engine swaps more readily but at the expense of extra interior room in the cab. Other than that there are differences like radiator placement and ahost of other small differences.
June 18, 2012 at 10:02 AM
okalover
Steve
Steve
Hank Onthewater
okalover
Steve
OKA-131 Home Page
OKA Camper Trailer
Last Edit: 01 Nov 2012 15:17 by dandjcr.
