Wheel Base
31 Oct 2012 21:53 #1 by dandjcr
dandjcr created the topic: Wheel Base
Forum Home > OKA Maintenance > Wheel Base
Hi All. I am new at the OKA scene & do not own an OKA yet. I have been trying to get as much info on the OKAs as possible. I know that the early ones had 4 cly & the later 6 cly, but is the wheel base the same on all of them? Where can I find specifications on the earlier models? Thank you Paul.
May 20, 2011 at 4:12 PM Flag Quote & Reply
Paul, David Ribbans (Dandj) posted some Oka dimensions here. That's for the older models; the newer models are available here at the time of writing.
Be careful of what you 'know'! I'm not an expert, but if there are more than half a dozen Okas out there with anything other than a 4cyl ex-factory, I'd be very surprised. Others will know better.
May 20, 2011 at 5:24 PM Flag Quote & Reply
Sorry,...no 6 cyl from factory,only 4 cyl diesel and V8 petrol for Saudi Arabia and when they try to enter the US market
May 20, 2011 at 8:51 PM Flag Quote & Reply
Thank-you Hal & Joseph. I had seen some 6cly OKAs for sale so I thought they were standard as both were later 90s models. Thanks for the links. Paul
May 21, 2011 at 7:17 AM Flag Quote & Reply
Paul the reason you probably saw 6cyl ones for sale is that Carpoint and other cars for sale sites pull up their own incorrect data when you fill out the ad.
Most sellers will correct this in the script of the ad.
May 21, 2011 at 7:29 AM
