Dash pods
31 Oct 2012 19:18 #1 by dandjcr
dandjcr created the topic: Dash pods
Forum Home > OKA Maintenance > Dash pods
James & Usha (THEByleDuct)
Has anyone had extra dash pods made up or know of a source for them? The XT is obviously limited with having the shorter 1/3 dash length pod.
Cheers - James
OKA #072
May 27, 2012 at 5:12 PM Flag Quote & Reply
James,I'm prety sure Allan have some at OKA parts Australia,if you need some dimensions,my cab is on a stand and it's easy to acces and you're welcome to measure
cheers,Joe
May 27, 2012 at 8:12 PM Flag Quote & Reply
Thanks Joe - I've been looking for an excuse to come and see your OKA and now I have an excuse I've moved up to Karratha for 12 months I'll contact Allan and see where I go from here.
Cheers - James
OKA #072
May 27, 2012 at 9:24 PM Flag Quote & Reply
James. I made up a central dash pod with the same dimensions as the RH pod from a sheet of aluminium, hinged at the back with a front panel for controls/displays.
There's tons of space inside and the original plastic tray can be retained.
May 28, 2012 at 12:05 AM Flag Quote & Reply
Looks great David - pretty much what I want to do. What thickness aluminium sheet did you use?
OKA #072
May 28, 2012 at 8:34 AM Flag Quote & Reply
James, it was 2mm sheet (you can buy 1200x2400 sheets from Ullrich Aluminium outlets).
It only requires a couple of gentle bends on each side and one at the back for the hinges, plus a few brackets to hold the front panel. I did consider replacing both pods with a longer LT type panel but this was much simpler and more useable.
I originally housed a laptop in it (which drives the 17in monitor) but I've since modified the LH pod for the laptop, which is more convenient.
May 28, 2012 at 9:26 AM Flag Quote & Reply
James,if the XT pod is what you're after i think i may still have the one from the old cab,will look for it and let you know.
cheers,Joe
May 28, 2012 at 10:18 AM Flag Quote & Reply
Thanks Joe - that would be great!
Cheers - James
OKA #072
May 28, 2012 at 11:44 PM Flag Quote & Reply
James, which ever way you go, if you house a lot of electronics or heat sensitive stuff inside, fit some ventilation grilles on the top and some holes at the back to provide air flow.
It can get pretty hot inside from the sun, rising header tank heat plus any self generated heat trapped inside.
For my laptop pod, I also drilled a few holes into the back of the a/c ducting to bleed a bit of cool air into the pod.
May 29, 2012 at 7:53 AM
