Engine swap
- Oka043
09 Jul 2020 09:44 - 09 Jul 2020 12:17 #1
by Oka043
Oka043 created the topic: Engine swap
Hello, I have recently brought a OKA so I am new to the OKA community and would like to talk with people who have done a duramax engine swap in there OKA.
If anyone is able to give me some advice have a chat about or a vehicle to look at I would really appreciate it.
Justin
Justin
Last Edit: 09 Jul 2020 12:17 by Oka043.
09 Jul 2020 19:27 #2
by Alister McBride
Alister McBride replied the topic: Engine swap
Where are you based Justin? I believe there are a few, one or more of the duramax guys may be nearby... most have gone the cummins 6bt route if doing an engine swap...
- Oka043
16 Jul 2020 20:36 #3
by Oka043
Oka043 replied the topic: Engine swap
Hello Alister,
I am in Comboyne on the mid north coast of NSW.
17 Jul 2020 04:48 #4
Peter and Sandra OKA 374 replied the topic: Engine swap
I'm at Dungog and Ralley is at Taree, we've both done 6bt's and 6 speed Allison's. The only Duramax I've seen is in Melbourne.
Do you have an engine and gearbox? there is a place in Qld that does duramax and Allison's into Patrol's and 200 series that can be a source of drivetrains. I've used his Allison to Patrol adapter for the transfer case.
- AngusM
10 Aug 2020 18:39 #5
by AngusM
AngusM replied the topic: Engine swap
Hi,
I'm involved with Oka #260 which had an engine swap in late 2012 to a 6.6L turbo Duramax with an Allison 1000 6 speed auto. The Oka is now unbelievably quick, Hal had it 0-100 in 8.34s and uses about 23l/100k with a small load and not much headwind. Happy to chat through some of the details if you need.
Angus
Angus
11 Aug 2020 05:46 #6
by Alister McBride
wow! I'd be surprised if those fuel figures were correct. I've had the perk down to 12L/100 at one stage but with the muddies around 15. Most report of getting around 16L/100 with the 6bt... I would have thought the electronically controlled Duramax would be closer to that than above 20 odd...?
