Oil capacity of 6 cylinder Perkins
06 Oct 2017 11:15 #1
by Paul Scherek
Paul Scherek created the topic: Oil capacity of 6 cylinder Perkins
Hello, Can anyone tell me please how much oil a 160 Perkins should hold? I have searched the net and elsewhere, but there seems to be no info available. Even the Perkins workshop manual only says "Fill to mark on dipstick". But I don't have the original dipstick.....
Thanks, Paul
Thanks, Paul
06 Oct 2017 13:09 #2
dandjcr replied the topic: Oil capacity of 6 cylinder Perkins
Paul, sump capacity seems to be determined by the application/vehicle the engine is in, rather than engine model.
The best I could find ( a 160HP in a boat ) is 8-10 US Quarts (7.5-9.5 litres), Which is about the same as the 4 cylinder Perk.
If the oil level has been OK, drain the sump and measure how much comes out. That will give you a clue as to how much to replace it with (plus a bit for losses), but probably a litre or so will still be around the engine so it's not an exact science.
06 Oct 2017 14:22 #3
by Paul Scherek
Paul Scherek replied the topic: Oil capacity of 6 cylinder Perkins
Thanks David,
Yes, it does seem to be application specific. I drained 16 litres out, which is a LOT more than I expected. Very nearly had a nasty upset on my floor - my drainer was full to the brim. I expected maybe around 12 litres, 50% more than the 4 cylinder.
I know that too much oil can be nearly as bad as too little - crankshafts whizzing through the oil can aerate it and make it less effective. Wish I knew more....
- OKA 138
06 Oct 2017 15:54 #4
by OKA 138
OKA 138 replied the topic: Oil capacity of 6 cylinder Perkins
Paul the Phaser 6 set at 180hp was fitted in the last of the Bedford Trucks model TL.
I know the 6354 model held 21 pints if thats any help,
Also don't let the crank hit the oil when its turning you could end up with a very expensive repair.
06 Oct 2017 20:05 #5
by mort
mort replied the topic: Oil capacity of 6 cylinder Perkins
Hi Paul,
The reason that there is no info in manual is because there is a number of sumps and 1 or 2 filters and any combination.
The 4 and 6 fill up to the same level no matter the sump or filter combination so you can use the dip stick from the 4 cylinder and either mark down from the top or just swap over but make sure that the tube is the same length from where it fixes to the block to the top where the stick goes in if not just compensate for the difference.
Fill to the mark and measure what goes in for next time.
Dave may be right with 21 pints but is it the same size sump in yours.
06 Oct 2017 20:26 #6
by outyonda
outyonda replied the topic: Oil capacity of 6 cylinder Perkins
Google your local Perk dealer, give eng no & he will tell all
07 Oct 2017 04:44 #7
by Paul Scherek
Thank you everyone for your replies. I am sure now I will be able to work it out, one way or the other.
- OKA 138
18 Sep 2023 14:18 #8
by OKA 138
HI Paul
I have been out of touch of late but we are still above ground and I have recently acquired a 6 cyl Phaser and am hoping I can pick your brains on a few things about fitting it into the Oka .
My email address is This email address is being protected from spambots. You need JavaScript enabled to view it. and phone is 0419869066.
Cheers Dave Gray Oka 137 my Forum address is 138 I have to catch Martyn to get it changed.
