2WD Oka curiosity
02 Dec 2018 21:09 #1 by Frank
Frank created the topic: 2WD Oka curiosity
I purchased some old Oka bits which according to the previous owner were originally from some of the 2WD Okas Argyle mine had. For interest sake I thought I would post here as it filled in a bit of my knowledge and removed some assumptions I had.
I had assumed the 2WD Okas would have had the tailshaft from the back of the gearbox. It appears that Oka made a transition piece the length of the NP205 transfer case. So same tailshaft, same coupler, same handbrake. All hanging off the back of the XT rear gearbox mount like the NP205 does.
Front axle is apparently still a Dana 60, same knuckles, brakes etc, just an empty pumpkin I assume, the inboard end of the spindle is sealed off and the outboard end of the hub had a chrome cover silicon-ed in place.
03 Dec 2018 05:37 #2 by Holmz
Holmz replied the topic: 2WD Oka curiosity
Frank wrote: I purchased some old Oka bits which according to the previous owner were originally from some of the 2WD Okas Argyle mine had.
A bit of a diamond in the rough (ruff) then?
03 Dec 2018 06:22 - 03 Dec 2018 06:23 #3 by outyonda
outyonda replied the topic: 2WD Oka curiosity
there was A dozen 2wd like that but most had an I beam front axle.
aparently it's an OKA thing
Last Edit: 03 Dec 2018 06:23 by outyonda.
04 Dec 2018 04:30 #4 by Peter and Sandra OKA 374
Peter and Sandra OKA 374 replied the topic: 2WD Oka curiosity
Oka also sold some cabs with rolling chassis, no drivetrain with beam front axles, they then had a wider bus body made and fitted with 2 + 2 either side of an aisle.
They were fitted with V8 Chev diesels and auto's.
