NT shackle pins
Dean OKA parts.
Cheers,joe
NT also had bi-metal bushes
Do'nt be missled by those who think they know all !!
OKA NT specific & as Joe said small modification will fit XT & LT
strongest pin;s & less moving parts:
When I did the upgrade several years ago, I use the NT pins.
are they prober NT or dodgy ones ?
there is A lot of NT pins out there now, Dean would be keen to hear of any issues.
you do A lot of loaded miles, weather the pins ware or the bush flogs out ?
- Bushwalk
- Bushwalk
I'm going to machine my own out of 4140, I'll machine a grease groove in them and get them induction hardened and see if they last longer when they're hard and better lubricated. The bushes are easily sources locally, i'll stick with the bronze bushes.
Ralley wrote: The pins are NT. I haven't had it apart yet to check how bad the bushes are but I have pulled some of the pins and some are well and truely stuffed. At the last RTA check they said that they would need attention before the next 6 monthly check. They have been in about 180000km's
There are some special drill bits that work on hardened steel. And they come in the size required for Zerk fittings.
YG dream drill.
The machinist used the ones without the cooling holes, and they reported to have went through like a hot knife through butter.
1/8" hole about 35-mm deep.
