URGENT Front Diff Spindle Assembly - Parts needed Oka #260
- AngusM
I'm new to the Forum but have been involved with Oka #260 for ever (Hal's nephew). We have recently had some trouble with the front passenger free wheeling hub (video attached) where the inner bearing has completely shattered itself.
Long story short...
Oka #260 will be on display with Rohny Dahl at the Perth 4wd & Adventure show at the start of November and we are urgently chasing a front diff spindle assembly specifically, the spindle and the thrust washer.
If you have one, or know where one may be please call me on 0474 297 812 or email This email address is being protected from spambots. You need JavaScript enabled to view it. so i can arrange to purchase it!
Thanks!!
If any of you are interested, you can follow the journey of #260 on facebook/ instagram at Explore West Aus
- ABE
Dean Robinson phone 0418943230
Your problem caused by lack on wheeling maintenance. You have done more damage than you think you need the spindle all bearings and seals and new throw out hud and you most likely have melted the out side of the hub to the 35 spline outer axle and if you drove it too far you will have damaged the outer hub that holds the bearing cups aswell. I know from experience doing the same thing in Esperance on tour actually doing work for the state parks fire people. My was caused by a broken brand new brake pad. We all learn the hard way.
They will have all the parts in stock. Take all the bits that you can recover including the good bits so Dean can check them to see what is damaged, as there could be more. You will need to check the other side as well ASAP if yo have not done them in the last 10,000 km or so as the beach work you guys do is hard on them.
ABE Tony
ABE Tony
- ABE
Dean should have all that you need and good luck, remember to do the other side. Mine actually failed due to putting in new brake pads that that some how broke the pad not the steel backing in two and the brake jammed on slightly and heated up the disc and the bearings failed, they where brand new that day. Was not a good trip, we where amazed we made it home as the assembly should off flown the coop.
Good luck.
ABE Tony
ABE Tony
- AngusM
We are running the front chrome-moly axles coupled to a Dana 60 with Warn locking hubs. The front passenger hub had a few issues which resulted it to over heat and pull itself apart over the last couple of months (it was driving fine, no real issues) however, a lack of maintenance on our part hasn’t helped.
I’ve been in contact with Dean & Martin who think they might have leads on the spindle assembly, all other parts have been sourced through Cass.
Will keep you in the loop with how it progresses.
- OKABloke
OKA 4x4 Facebook Page
- OKAPETE
AngusM wrote: Thanks for the information Abe.
The Yukon locking assembly and the schmicko lock nut assembly (forgot the name) may also be worth considering?
Alister McBride wrote: Holmz i think you might mean the stage 8 locknuts?
Yeah... I was on stage 4 beers with the AFL
- AngusM
Thanks for all the advice!
Oka #260 was back on the road this morning after a massive effort from Cass Jones getting it ready just in hime for this weekend's Perth 4wd & Adventure Show at McCallum Park.
We ended up needing new spindles/ wheel bearing assemblies and free wheeling hubs on both the driver and passenger side, passenger side blown up and drivers side full of rust! This is probably down to a lack of preventative maintenance by myself, I don't think these have been looked at since the conversion was completed in 2012 - a mistake not to repeat.
I've attached some photos of the driver side hub...
What is wrong with yours?
Just pull it apart and go hard at it with awire brush and see if it is useable or not.
If you are not sure, then whack it into a wooden box of spares??
- AngusM
