Air operated coach step issues.
- mannixx
02 Dec 2012 14:16 - 02 Dec 2012 14:18 #1
by mannixx
mannixx created the topic: Air operated coach step issues.
Can anyone tell me where the main power supply wire for the air compressor originates.My compressor is located behind the dust cover on pass. side of vehicle. I must have a broken wire somewhere in the circuit. I have power on the switching side, but not the supply side ? all fuses seem okay, has anyone else had issues with this? we have kids the a manual step mod. is not an option just yet.
Last Edit: 02 Dec 2012 14:18 by mannixx.
02 Dec 2012 15:04 #2
by PeteFox
PeteFox replied the topic: Air operated coach step issues.
My compressor had a glass type fuse in the line. The internal connections were dodgy so I took removed the fuse assembly entirely and used a standard two prong fuse instead. Fixed.
- Chalkie
02 Dec 2012 15:54 #3
by Chalkie
Chalkie replied the topic: Air operated coach step issues.
There is a 20Amp fuse in rear control behind LH seat.
- mannixx
02 Dec 2012 15:55 #4
by mannixx
mannixx replied the topic: Air operated coach step issues.
thanks for that. that was my first port of call. i did exactly the same repair. also re soldered any connection i could get to.
does the pressure control switch on yours have 3 wires coming in? 1X red (thick) 1X black (thick) & 1X red (thin/fine), the problem i'm having is with the thick red one. i'm trying to trace that back, but it disappears into the loom under the rear fuse panel (i think). any ideas??
02 Dec 2012 18:17 #5
by Outback Jack
Outback Jack replied the topic: Air operated coach step issues.
I just removed all the air step stuff.
It wasnt working when I brought the bus, and being in the bush have decided not get it working at this stage.
- Chalkie
03 Dec 2012 05:34 #6
by Chalkie
Fuse gets power through fuseable link 23 30Amp
- Chalkie
03 Dec 2012 05:36 #7
by Chalkie
And also rear ignition relay
