Alternators
- Peter334
11 Dec 2012 17:35 #1
by Peter334
Peter334 created the topic: Alternators
I am looking at fitting a new alternator to our oka at least 120amp can anyone tell me what type to get, ours is original 85 amp and with all the gear on board it needs to be higher, cheers peter
11 Dec 2012 19:04 #2
by Outback Jack
Outback Jack replied the topic: Alternators
Hi Peter,
Been mentioned before many times. 120 Amp is common upgrade.
Part number is Bosch BXU12121A as you have an 85A alternator now, you can use existing mounting brackets.
I had to change mine as it had a 55Amp alternator
12 Dec 2012 05:55 - 12 Dec 2012 05:56 #3
by Peter_n_Margaret
Peter_n_Margaret replied the topic: Alternators
Does that 120A Bosch have a tacho signal output Jack?
Last Edit: 12 Dec 2012 05:56 by Peter_n_Margaret.
12 Dec 2012 08:54 #4
by Outback Jack
The following user(s) said Thank You: Peter_n_Margaret
