Gear and diff ratios
01 Nov 2012 13:44 #1 by dandjcr
dandjcr created the topic: Gear and diff ratios
Forum Home > On the Road > Gear and diff ratios.
Where do I find the standard ratios for the gearbox (all gears), transfer case and diff for a standard XT?
Also looking for a torque figure for the Perkins 110.
September 18, 2012 at 9:17 PM Flag Quote & Reply
4.88 is the diffs.
Gearbox depends on model number.
Not sure of the NP205
What you up to Peter
September 18, 2012 at 9:40 PM Flag Quote & Reply
Upgrading GVM.
Info required by engineer.
September 18, 2012 at 10:08 PM Flag Quote & Reply
OK, thought you might be looking at something different.
Service Manuals have the information you need, but if you get stuck PM me. Other wiser ones on here will have the info I am sure.
September 18, 2012 at 10:13 PM Flag Quote & Reply
Diffs 4.88:1
Trans (Model T5 - X - 2276 i'm assuming this is standard you can check the plate):
1 - 5.36:1
2 - 2.62:1
3 - 1.51:1
4 - 1.00:1
5 - 0.79:1
(I didn't realise it was an overdrive until i just read the manual!)
Transfer case NP205:
Low - 1.96:1
High - 1.00:1
Hope this helps!
Alister
September 18, 2012 at 10:49 PM Flag Quote & Reply
Brilliant, thanks fellas.
Any clue on the 110s torque?
September 18, 2012 at 10:59 PM Flag Quote & Reply
From the Oka training manual Part 1
Perkins Phaser 110MT, Direct Injection, 3.99 litre.( Military Spec.) Torque 354 Nm @ 1600 RPM.
Max. eng. speed 3150 RPM
3150 RPM?? KaBoom !!
September 19, 2012 at 5:45 AM Flag Quote & Reply
"3150 RPM?? KaBoom !!"
No, but it does get noisy
September 19, 2012 at 8:11 AM Flag Quote & Reply
Thanks guys.
Looking for a 20% upgrade on GVM. See how I go.
September 19, 2012 at 10:15 AM
